PEX would be the last way I would run those lines and depend on them keeping the pipes rigid. The company SHOULD have a bracket to support the pipes to the tub's overflow. If not Kohler has one that can be adapted by drilling and tapping an opening in the back of the overflow fitting. Other companies use set screws to anchor theirs, but without something to anchor it, you WILL damage the pipes eventually because of the leverage you can develop with those long pipes.
