Thread: Flappers' Life
    DIY Junior Member sawsaw's Avatar
    Dec 2009
    MN
    Default Flappers' Life
    My Drake of four years has started having intermittent leaking under the flapper. No sign of sediment. Is there a rule of thumb life span to the flappers?
    It very much depends on the water you have.
    i have sen them go out in as little at 2 years. it is rare though.
    Taylor Allen
    Website: http://www.rtaplumbing.com
    Do you use a chemical cleaner that goes in the tank? They will shorten the life span of flappers considerably. That's a subtle way of saying don't use chemicals in the tank.
