Thread: Leak at ball valve nut
    DIY Member spta97's Avatar
    Dec 2009
    New York
    Default Leak at ball valve nut
    Hi all,
    I had to rerun the copper lines to my bathroom and was replacing the old bendable copper pipe so I had to do a lot of close-quarter fittings in the ceiling to get the pipe to go where I needed it to - it was a complete nightmare (I didn't know about the heatsink trick at the time).
    After several failed attempts (and a pretty bad solder burn) I got all 4 ball valves and multiple fittings soldered in a very tight area but I just noticed (a few months later) that one of the 3/4" ball valves has a slow drip from under the nut where the handle is attached.
    Is it possible that I got it too hot and melted something or is it just a matter of replacing a washer? I want to do everything in my power not to disturb the joints.
    Thanks..
    master plumber/gas fitter pipepusher's Avatar
    Dec 2009
    Nebraska
    Try to tighten the nut.
    Dec 2009
    New York
    Default Fixed!
    Well that seems to have done it! Thanks Pipepusher!!!
    I used blue handled ball valves for the bathroom and red handled ones for the kitchen so I could tell them apart. The red ones appear to be a solid piece whereas the blue ones have a packing nut. I also checked the other blue one and that one had some green discoloration so I tightened it as well. The one that was actually dripping took a quarter turn of the wrench before it gave resistance so it was defintely loose.
    I guess that you are meant to tighten these during installation so thanks again and Merry Christmas!
    Dec 2009
    Nebraska
    Thumbs up leaky ball valve
    You are welcome.Glad to help.
