Results 1 to 5 of 5
Thread: Heating formulas
    DIY Junior Member
    Dec 2009
    Mass
    Default Heating formulas
    I am installing a new hot water boiler replacing the existing one. Have added more space. Where do i find a calculation sheet to determine boiler size?
    DIY Member Lightwave's Avatar
    Aug 2007
    Vancouver, BC
    You're talking about a heating boiler, right?
    What you need to do won't fit on one spreadsheet. You need to do a Manual J load calculation to find the heating needs of your space and then size the boiler as required. Manual J is very involved; the only practical way to do the calculation is with specialized software. HVAC Calc and RHVAC work well.
    Aug 2009
    Midwest
    Even Manual J is just an estimate.
    Have you heated your home and additional space through a winter with the existing boiler? If so and if you have a monthly record of utility usage, then you could combine that with daily average temps over the same periods to estimate actual sizing required. The usage over a given time period with given average temperature can be scaled to determine peak usage at the design temps.
    Dec 2006
    http://www.hvaccomputer.com/hvac/tofc2.asp
    homeowner version is 50$.
    This is free, but I'm not sure how thorough/accurate it is.
    http://www.bgmsupply.com/calculateheatloss.asp
    Also very basic / simplified, but will give you a rough idea, at least:
    http://www.pprbd.org/plancheck/Heat Loss Table.pdf
    Master Plumber Mark:
    do not hit your thumb...
    __________________
    Previous member
    Jul 2009
    North of the Mason dixon Line
    www.taco-hvac.com has a free version that is very good
