A tub drain that fits a 2.5" drain opening?
gus514
Northern Virginia
I'm replacing the drain system on an older cast iron bathtub, and the drain opening at the bottom is 2.5" in diameter, which leaves a lot of extra room when a standard 1.5"drain is put in. The rubber washer at the bottom barely has any overlap with the edges of the opening, so I'm afraid it's not going to make a very good seal. Nobody seems to stock or even be able to special order any larger drain sizes.
Any suggestions?
