Results 1 to 2 of 2
Thread: Moentrol spool problem help
    DIY Junior Member
    Dec 2009
    new jersey
    Default Moentrol spool problem help
    Any tips on removing the moentrol balancing spool? I've tried a large screwdriver and a flat wide chisel with no luck. Also sprayed with white vinegar? Need to get this out without stripping help??
    Default spool
    I have had luck by "drifting" it using a hammer and chisel in the screwdriver slot to get it started. Once you move it even a little bit the large screwdriver will work.
