Results 1 to 12 of 12
Thread: Painting a toilet for a sports fan
    Steeler Fan jecarver229's Avatar
    Dec 2009
    Beaver PA
    Default Painting a toilet for a sports fan
    I am from the Pittsburgh area, and a big part of Pittsburgh is the Steelers, and a big part of that is a strong animosity for the Browns and Bengals.
    That being said, what my brother has asked for this Christmas, is a toilet painted orange... that says Ohio on the bottom... (the O would be part of the drain) and he wants to put Benglals and Browns logo's on it so that he can "poop" on those teams on a daily basis.
    Now, I am fairly artistic, so painting this toilet is not a problem, the question I have is what kind of paint or glaze to use so that it doesn't end up chipping?
    Any suggestions would be greatly appreciated.
    Dec 2009
    Beaver PA
    Is everybody too busy laughing at me to answer? I know this is probably a strange question.
    It may take a day or two for this unusual question.
    Toilets are glazed in a kiln.
    I've never seen anyone paint one before.
    But, I'm sure it could be done.
    Plumber krow's Avatar
    Feb 2008
    Ontario, Canada
    It can be painted, but it won't last long submerged underwater. It will tend to peel. I've seen it done once and I wasn't thrilled at the look of it. As it was told to me, it was baked over top the existing color. I'm not really sure about the process though
    Default paint
    Use an "appliance" epoxy paint and it should last fairly long. Does he feel the same way about OSU? If so he could go for a triple header.
    If you had access to a large enough kiln, you might be able to use glaze, then refire it. If not done carefully, it could shatter. But, if it didn't, it would be as durable as the original finish. It might be a pain to clean, since it probably wouldn't be as smooth, though.
    DIY Member JCturboT's Avatar
    Mar 2007
    Massachusetts
    How about using a swimming pool paint?
    It is holds up to chlorine in a pool regular toilet water should be a snap.
    Jeff
    Jul 2007
    USA
    I would use enamel paints with a clear laquer coat on top.
    They would look awesome.
    I would definitely use a quality, well-priced toilet for this. Like an American Standard Cadet 3.
    Extreme DIY Homeowner Scuba_Dave's Avatar
    Jan 2009
    South of Boston, MA
    Airplane paint
    DIY Handyman (not 4 hire)
    I have enough to do to my own house
    Any of the suggestions would work but the difficulties would not only be finding the right paint/method that would hold up under use for any length of time but ensuring an even application with no rough spots that would impede extraction and leave remnants
    Knowing the intention, a few skid marks and stains may be appropriate.
    I've done some research on custom paint jobs and the only way to make something that will be permanent is to get a manufacturer to paint, glaze, and fire the bowl and even then it's pretty much cost-prohibitive.
    I wanna see a pic too!!!!! if it turns out good can i pay you to do me one for dallas
    Default fan
    Steeler fan, are you getting royalties for JECarver using your avitar logo?
