yelnats69
Recently, I have noticed a noise in the water pipes, the easiest way to describe it it sounds exactly if the toilet ball valve is leaking or if someone pushed the ball down for a few seconds; I first though was to check all the toilets to make sure the flapper valves were holding, I finally traced the noise to the pipes at the washing machine, every 10 minutes the sound can be heard in the pipe, in the region where the washing machine flexible pipes connects to the house water supply there are two Oakley Hammer arrester valves, at the hot and cold washing machine feed, when these fail do they have any symptoms? could either one of these be causing the noise? or do you think that the washing machine water control valves are leaking,
The noise is exactly every 10 minutes, and sounds like a phiiishhhhed sound. Seems to end with a valve closing Exactly the noise you would expect from the flapper ball valve being pressed.
There are no signs of leaks or where the water (that is if the noise is a rush of water) could be going.
