Results 1 to 6 of 6
Thread: Black stuff came out of tub spout for first minute or so.........
    DIY Junior Member
    Sep 2009
    kaleefoorneeuh
    Default Black stuff came out of tub spout for first minute or so.........
    OK so I found an old thread here forwarded from a Yahoo Answers question.
    So, after a customer master shower install, we haven't used shower #2 in a while. This last stretch was about a month. Turned on the hot water today & noticed occasional spurts of black stuff. My jaw dropped. Lasted for about 30 seconds or so and spurted about every 3 or 4 seconds.
    14 yr old house
    4 yr old GE 12yr heater from HD
    Mixet valve
    In regards to the black stuff, it appeared to be water soluble as it appeared to dilute in the water and quickly disappeared. No stains, or settling chunks I could hang onto. Wife saw it too, so I definitely wasn't seeing things.
    Any insight appreciated.
    Aug 2009
    South*East
    Quote Originally Posted by Esquire View Post
    Is there hydronic heating in your home? Could be from a cross connection between potable and non-potable water if there is no proper backflow prevention device. Thats a bit of a long shot, but I'm bored and thought I would through somethign out there.
    Sure is a long shot. If there was a cross connection between the two the boiler pressure would be to high and blowing off the relief valve.
    John
    Plumber Esquire's Avatar
    Nov 2009
    Newfoundland
    true enough, I just figured if I threw something out there people might start coming up with realistic scenerios
    Aug 2009
    South*East
    It sounds more like there is a galvanized nipple in the water system.
    John
    DIY Junior Member
    Sep 2009
    kaleefoorneeuh
    No, definitely not hydronic heating but nice shot outta' left field for the boredom factor......
    My guess is it would be stuff(seals?) in the mixet valve for a couple reasons.......
    #1.) No other taps in the house are showing such behavior.
    #2.) This shower is the 2nd closest thing to the hot water heater besides the washing machine.
    I haven't turned the water on since then but my guess is that it'd probably be fine today. I'm going to try & wait 1 week whilst watching the other taps to make sure nothing shows.
    But if you twist my arm, I'll turn it on now.
    And I'll also tell you what you're getting for Christmas.
    Default hydronic
    That is about the "longest shot" possible. One reason, even if it could happen which is astronomically unlikely if not impossible, is that the boiler's feeder is NOT connected to the hot water system. There are many common possibilities when the water has been stagnant in the line for a fairly long time.
