If the washer box was done correctly in the first place there is probably a trap in the wall between the box and the floor.
Uncap the original 2" drain pipe under the house if it is capped. Pour some water into the laundry drain box. Snake something down the drain. If it only goes a few feet before meeting some resistance and comes up soaking wet I'd say you have a trap.
I am going to fix the venting issue. Should I relocate the p-trap? The floor is concrete and the wall is cinder block.
