Results 1 to 6 of 6
Thread: Cold weather glue
    Default Cold weather glue
    What is too cold to be using the priming and glue on pvc ?
    I don't have a can handy. I am thinking it says 50º
    Previous member
    Jul 2009
    North of the Mason dixon Line
    Take it inside at night and keep it fairly warm during the day, it's fine.
    Thanks for the help. Im having a plumber change a few fittings on some drain pipes and I didnt know how concerned I should be with the below freezing temperatures as night but I guess as long as it has time to set through the day then they should be fine.
    Jan 2006
    Rosedale, Md
    You should check the can to see what the temp. range is. Oatey makes one thats good to 5 deg.
    Thanks shacko I will have to see if I can find out what he uses. The temperatures have been great the last couple of days.
