Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
Thread: Malfunctioning York Gas Furnace?
  1. #16
    DIY Member walds11's Avatar
    Nov 2009
    Philly, PA
    What does the repair entail? Approx how much?
    Quote Originally Posted by Doherty Plumbing View Post
    I would agree especially if this furnace has the old style honeywell limit/fan switch.
  2. #17
    Jun 2009
    Penticton, BC
    Quote Originally Posted by walds11 View Post
    The repair entails removing 4 screws, moving a couple of wires over to the new limit switch and then reattaching the 4 screws.
    If all goes well you can easily change one out in 30 mins.
    Take a picture of the front of the furnace for me ok.
    Cost? Less than $70 USD I would think... The part is about $70 CAD up here...
  3. #18
    Nov 2009
    Philly, PA
    You mean pop the front panel off the furnace and take a pic of that?
  4. #19
    Jun 2009
    Penticton, BC
    Yes .........
  5. #20
    Nov 2009
    Philly, PA
    This is the best I can do.
  6. #21
    Jun 2009
    Penticton, BC
    Yes replace that limit control you took a close up of in the 2nd picture.
    All you have to do is basically wire the new one the exact same as that old one.
    On your old limit you'll notice that on the right side of it (when looking at it in the orientation it's in now) you'll see a brass jumper. It will either be intact or broken. Make sure you the new limit matches this. IE if it's broken break the one on your new one, and if it's not broken leave your new one alone.
    This jumper is used to determine if you have 120v or 24v controlling the circuit.
  7. #22
    Nov 2009
    Philly, PA
    I must be blind, but where is the limit control? I don't see a brass jumper. My HVAC guy is coming over on Wednesday to install a hot water heater. I'll run it by him.
  8. #23
    Previous member
    Jul 2009
    North of the Mason dixon Line
    It's that thing with the circular disc and three black wires running into it and the cover off
  9. #24
    Nov 2009
    Philly, PA
    Now I see it. Thanks!
  10. #25
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    My HVAC systems are about 18-19 years old. Maybe no need to rush to replace the new systems even if I have to spend small amounts of money for mainatence and repair each year?
    I have a spreadsheet on my other computer that tells when to replace equipment. It's one of many equipment replacement strategies but this one does not take The Cost of Money into account.
    Now that I know how to post a "print screen" I'll try to find the thing and post it.
    With this and the expected lifetimes of equip. I think you can make a pretty rational and informed decision about replacements.
  11. #26
    Aug 2008
    MD
