Maybe, but it probably isn't worth quibbling over. The plumber might have suggested it, but if you had no troubles before I doubt he would have, and there is a fair chance that a homeowner would reject it for that same reason. Realistically, you've got the previously mentioned tank cost, a special tee (depending on the tank nozzle type), a strap, and some misc. materials. If you have everything drained for him it is less than an hour of actual labor. But that first hour of labor is probably charged out at $50-100. So assuming you pay something for the install itself which you would have paid anyway the differential cost of doing it now vs. initially is perhaps ~$50 for his extra trip.
Expansion tanks aren't code required in many areas including mine. Instead they appear to be an "as needed" thing. I've never had need of one before in any of the homes I've inhabited in various states. That is, I've never had a system that didn't soak up the thermal expansion somehow without the expansion tank. But now I do, so I had one installed.
Just guessing, but on most homes connected to municipal system if you installed a test gauge you would probably find the thermal exp. pressure spikes exceed 80-100 psig. These should probably have thermal expansion tanks, but most often don't. Some can relieve back to the supply, but new higher system pressure water pumps/towers and checkvalves might prevent that...tightening of the overall network and toilet fill valves/etc. is likely to increase the need for these expansion tanks in the future.
I guess I will be calling the HVAC tech to install the expansion tank.
