Thread: radiant heat in the walls?
    DIY Member rrekih's Avatar
    Oct 2009
    Canada
    Default radiant heat in the walls?
    I have a low ceiling in the basement.
    I was planing on using hydronic radiant heat panels for the basement.
    The main floor is radiant underfloor heat.
    Instead of using heat panels can I run the pipe up and down the walls and have the whole wall as the heat source?
    Jan 2009
    Radiant walls work, and work well, using the same techniques & materials used for radiant ceilings. Be sure to insulate between the radiant tubing/plates and the foundation/exterior wall. Put the (Canadian code-required) vapor retarder on the warm (interior) side of the insulation.
    Oct 2009
    Canada
    I have been thinking of using inside walls????
    Or I have an unique situation, I have built a wall in front of the existing foundation and stud wall.
    Web Development | HVAC patsfan78's Avatar
    Jun 2009
    Maine
    Radiant can be done in the walls. It works. But remember people hang pictures, put holes in, run wiring, and abuse walls a lot more than a floor. So the radiant tubing in a wall has more opportunities for damage than it would in a floor. A future potential buyer of the home may not care for it. (A radiator is, obviously, a much more visible object.) Not saying and can't or shouldn't be done, just food for thought.
    Mike
    HiTech Heat, LLC
    www.HiTechHeat.com
