Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 69
Thread: How to fix a dripping Moen shower faucet?
  1. #46
    DIY Junior Member jrob455's Avatar
    Dec 2009
    Houston, TX
    I finally received the replacement cartridge from Moen--they sent it for free, but tried to talk me into paying to get it rushed--and once I put it in, the dripping stopped completely. I did gently polish the inside of the fixture with some rouge cloth--vinegar alone wasn't getting rid of a couple of deposits that had built up over time, and I was concerned that they might have been breaking the seal and causing the dripping.
    So here's another example of the factory part fixing a problem that a generic replacement didn't--I'm a believer! At least the local hardware store refunded my money for the generic cartridge.
    Thanks again for the help, and Merry Christmas and Happy New Year to all.
  2. #47
    DIY Junior Member woody p's Avatar
    Dec 2009
    Illinois
    Default Oh no!
    Don't fret about the "B". There are ONLY TWO Moen cartridges, the brass one and the plastic one. We recommend the plastic.
    If they are selling a cartridge for 12 bucks or so, it may be a generic. We recommend the genuine Moen piece, which is usually $15+. If you think that spending $35 to repair a faucet is anuything other than an incredible bargain, wait 'til you get the bill from the plumber you have to call because you tried to get it out without the $15 tool, and screwed up the body. Add a couple of zeros!!
    I used the tool to remove the stem but apparently I didn't remove the entire stem. The part I did extract is brass but it does not look like the replacement. Do I really have to call a plumber to get the rest of it out... or is there another tool?
  3. #48
    DIY Junior Member ClayTwo's Avatar
    Jan 2010
    Greenville, SC
    Default What did I do wrong?
    I have almost the same equipment as was first reported in this thread. Only the outside handle is different. My original problem was that sometimes the water changed temperature from hot to cold unexpectedly occasionally. My shower is only 5 years old.
    Called Moen and got two replacement parts, a 1423 spool and a 1225 cartridge. The result after installation of both is a shower that continually runs at a low pressure. Can't change the pressure or temperature.
    I did lose the retainer pin in the wall somewhere. Made a temporary one out of a plastic coated paper clip.
  4. #49
    DIY Junior Member Snowbirdad's Avatar
    Feb 2010
    Haines City Fl
    I have replace the cartridge on my moen single handle shower faucet with a danco MO-1 and I didn't have any tempter control,so I took it out and saw that some of the O rings where torn , I replace them and reinstall it but had the same problem ,then I decided to replace the O rings on the original and put it back in but I still have no tempter control what am I doing wrong?
  5. #50
    Plumber krow's Avatar
    Feb 2008
    Ontario, Canada
    What do you mean by tempter control? Are you talking about pressure balancing?
    If so, your balancing spool needs attention/replacement
  6. #51
    Feb 2010
    Haines City Fl
    The faucet was leaking so I replaced with the danco cartridge and after I replaced it no matter which way I turn the faucet it made no difference in the tempter it stayed warm as if both the hot and cold were on. I don't know what a balancing spool, is something in the body of the faucet?
  7. #52
    Feb 2008
    Ontario, Canada
    I have to say that the danco spindle is your problem. If I understood you correctly, It seems that the hot and cold are mixing in any position that the handle is in . Where I am , the danco is almost obsolete. We now use the plastic spindles with lifetime warranty.
  8. #53
    Feb 2010
    Haines City Fl
    What bothers me is the original cartriage never had that problem until I put it back in ,but I guess I'll try the plastic one and see what happens. Thanks
    Is the plastic cartridge made by moen ?
  9. #54
    Feb 2008
    Ontario, Canada
    Made by moen #1225B
  10. #55
    DIY Junior Member korkiley's Avatar
    Feb 2010
    Vermont
    Default Successful cartridge replacement--but a mystery!
    My Moen shower faucet was leaking and I followed the instructions here and easily repaired it. At first, I was confused by the black plastic removal tool that came with my genuine replacement cylinder. Since the instructions didn't describe the part, I thought it was part of the cylinder and, until I realized it's purpose and used it to turn the old cylinder a bit (I guess it just loosens things up a bit because there are no threaded parts.) I was unable to remove the old cylinder. But once I turned the cylinder a bit, I screwed the faucet handle back on and easily pulled the cylinder out.
    OK. That is all common, but here comes the interesting part. I live in a condo and have been plagued by a vibration in the cold water supply line (I feel/hear the vibration in the pipe that supplies the water heater) for two or three years. It can happen when you turn on a faucet (about any faucet in the place) or it can happen in the middle of the night when we aren't using the water at all. I have been very suspicious of a relationship with the use of water in the neighboring condo.
    My Moen faucet began leaking two days ago when I was replacing a washer in the outside sill cock. I had opened all of the faucets to drain the pipes. When I had finished my washer replacement I first turned the main shutoff back on and then proceeded to turn off all the faucets beginning in the upstairs bathroom. But when I tried to turn off the Moen shower faucet in the upstairs bathroom, the faucet would not shut off. I kept turning it back and forth and pushing in and out and eventually I was able to push it in again. This was interesting because I suddenly remembered that the same thing had happened a few years ago and I now wondered if this could be related to the vibrating pipe, and maybe it had all started a few years ago after this incident.
    But back to the present--I have no idea what happened this time, but for a peaceful day after this, the vibration seemed to be gone. However, yesterday morning I discovered that the Moen faucet that had stuck was leaking, and that is what brought me to find this excellent thread and easily repair the problem. The sad news is that the pipe vibration is back--but there is more!
    I was showing my wife the old cylinder and how it worked. While doing so, I noticed some white material in the water inlet area and after prying and tugging a bit, I extracted a piece of plastic. I knew immediately what it was!
    About two years ago and after the vibration had plagued us for about a year, we replaced our water heater. When the plumber disassembled the hot water outlet pipe, he discovered several pieces of white plastic jambed in the copper pipe. He determined that the white plastic cold water inlet tube (or hot water outlet tube--I forget which) had disintegrated and gotten forced out into the hot water line. I can now see that pieces of this tube must been forced much further from the source and perhaps that was causing the vibration somehow.
    Perhaps I shouldn't have gone into all this detail with this problem in this thread but I couldn't resist because of the chain of events and the possible cause and effect. Hopefully there might be an enthusiastic plumbing sleuth that will read this and shed some light on what is threatening to become a cold case!
    Kor Kiley
  11. #56
    Feb 2008
    Ontario, Canada
    Well, You may not be out of hot water yet (no punns intended). I suspect that there may be more plastic pieces in the water pipe. Its only a question of "where they will end up". Usually they will stay lodged . but if anybody shuts off the water or disrupts the water flow, its a good possibility that they will move. I am suspecting one of 2 things.
    1) plastic peices may have become lodged in a hot water shut off valve serving one of your fixtures
    2) the vibrating could be unrelated and you should be looking at a dripping flapper and bad ballcock in your toilet. Your comment here points in that direction.
  12. #57
    Feb 2010
    Vermont
    Yes, I would be very surprised if there were no more pieces in my lines. I recently managed to cough up a piece by removing the aerators from the faucets and running the water on full for a while. Is there some method I could use to try to flush out the rest?
    As to the toilets, I recently replaced the flapper and ballcock on my upstairs bathroom. I've also replaced the ballcock downstairs and I've experimented by closing the shutoffs to both of these toilets. Shouldn't the problem disappear while the shutoffs were closed? Unfortunately, it did not.
    Thanks for your help!
    Kor
  13. #58
    1/4-turn ball valve shutoffs are better at passing crud in the lines than the multi-turn valves.
  14. #59
    Feb 2008
    Ontario, Canada
    Quote Originally Posted by korkiley View Post
    Not unless you are replacing any valves or do a re-pipe at portions of your system. Problem is there is no way to determine which parts of your system have peices.. Be patient, they will eventually move to the aeraters, as you found out.
    Kor
    further investigation is defenitely required.If nobody is using the water in your unit, then the problem may be coming from another unit , above, below or next to you
  15. #60
    Feb 2010
    Vermont
    Quote Originally Posted by krow View Post
    Interesting that you should say that. I had almost forgotten--when the problem first appeared, there seemed to be no relationship to what we were doing and when we were hearing the sound. Not only that, but I was fairly certain that I had only heard the sound when the neighbor was home. I finally asked her if she had been hearing the vibrating noise that we were. Much to my surprise, she said that she had heard nothing. She agreed to run water and flush toilets and all kinds of things at her place so I could see if a cause and effect was at work. After about 15 minutes she returned to our place and said that she had tried all the activities. Again, I was surprised to find that nothing had happened in our unit.
    Finally, after about ten or fifteen minutes, there came a long vibration! So, at least my neighbor knew that I wasn't making it up because I was standing talking to her when it happened.
    Gradually, over a year's time, the nature of this even changed. Now there is a direct cause and effect in our own unit. Usually we hear the vibration just as we are turning on the water, especially if the faucet is just cracked. Once turned on full, the noise disappears. Sometimes we hear the sound out of the blue. In this case, turning a faucet on stops the vibrating.
    By the way, we have an end unit, so we only have the one neighbor.
  1. No hot water from Moen shower faucet
    By timwise999 in forum Shower & bathtub Forum & Blog
    Last Post: 09-06-2010, 08:09 AM
  2. Moen Valve won't stop dripping
    By Henry G in forum Shower & bathtub Forum & Blog
    Last Post: 05-10-2010, 02:38 PM
  3. No hot water on Moen Shower Faucet
    By CMWill46 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-07-2009, 03:29 PM
  4. Moen Shower Faucet Leak
    By rapah in forum Shower & bathtub Forum & Blog
    Last Post: 11-11-2007, 03:15 PM
  5. dripping single handle shower faucet
    By pkbertram in forum Shower & bathtub Forum & Blog
    Last Post: 09-20-2004, 11:38 AM
