Page 1 of 5 12345 LastLast
Results 1 to 15 of 69
Thread: How to fix a dripping Moen shower faucet?
    DIY Member walds11's Avatar
    Nov 2009
    Philly, PA
    Default How to fix a dripping Moen shower faucet?
    How do I go about fixing this? Very light dripping, but annoying. Attached is a pic of my shower set-up. Thanks in advance.
    I would guess Moen 1225B cartridge.
    Nov 2009
    Philly, PA
    Thanks Terry. Is this something I could pick up at my local Sears Hardware store? Can you provide me with instructions?
    Plumber jimbo's Avatar
    The moen plastic pull out cartridge is widely available, certainly at Ace or blue or orange, and probably also at a sears outlet. There is a removal tool which is usually necessary, and you can buy that at any place that sells the cartridge.
    Nov 2009
    Philly, PA
    Plastic pull out cartridge? It looks metal to me. I was able to take the handle off. That is the easy part Do I need to turn the water off to get the cartridge out? I need more help. Thanks!
    Default Moen
    If it is a metal stem, then you might need a plumber to extract it because you will not have the tool(s) needed to do it.
    Plumber krow's Avatar
    Feb 2008
    Ontario, Canada
    -Pull off the face plate
    -pull off the sleeve
    -Shut off your water and drain the system
    -pull up the retainer clip and remove it (do not lose it or break it)
    - Use your puller or the plastic cap that comes with the new 1225B catridge to move/dislodge the entire cartridge then pull entire catridge with a sturdy yank.
    -Replace/reinstall new 1225B cartridge and retainer clip
    The rest is easy.
    Default moen
    quote; - Use your puller or the plastic cap that comes with the new 1225B catridge to move/dislodge the entire cartridge then pull entire catridge with a sturdy yank.
    Spoken like someone who has NEVER had to remove a stuck brass stem from one. The "plastic removal cap" is a joke for anything other than a plastic stem which is loose enough that it does not need it.
    Nov 2009
    Philly, PA
    I am at Lowes right now. Lowes has replacement cartridge part 1225, not 1225B. The part is $19.97. Will this part work?They have the cartridge puller tool, $14.97. Wow, the job will cost me about $35, unless I can find the parts somewhere cheaper.
    Don't fret about the "B". There are ONLY TWO Moen cartridges, the brass one and the plastic one. We recommend the plastic.
    If they are selling a cartridge for 12 bucks or so, it may be a generic. We recommend the genuine Moen piece, which is usually $15+. If you think that spending $35 to repair a faucet is anuything other than an incredible bargain, wait 'til you get the bill from the plumber you have to call because you tried to get it out without the $15 tool, and screwed up the body. Add a couple of zeros!!
    Nov 2009
    Philly, PA
    So, as long as I have the puller and the correct part, I good to go? I am fairly handy, but generally don't like to mess with plumbing and electricity.
    Feb 2008
    Ontario, Canada
    Are you kidding me!?!?
    You, my freind , haven't got the slightest clue of my abilities and what I am capable and licenced to do! You don't know me! So you can't sit there on your high chair judging me!!
    I'm finding alot of the veterens of this site very insulting and making judgments about anybody else , especially the noobs that just want a quick answer to their problem.
    Instead of critizing my credentials, why not actually try to help and give YOUR opinion on how to fix his dilema!
    For your information, In 30 years that I have been plumbing , I only came across 1......... count them..........1 moen cartridge that I was not able to pull out........... and I ended up drilling that one out with no problems.
    you really need to get more hands on experience in plumbing repairs
    hj plumbs in Arizona.
    The water there must be very bad.
    There are several plumbers that report that Moen gives them issues.
    That is not the case with normal water, like the stuff we have in Seattle.
    Moen is a breeze to repair here.
    We pull the clip, pull the cartridge, and it's all downhill from there.
    But then, we have good water here.
    And get the genuine Moen, don't waste money on generic parts for these.
    I have never needed a "removal tool" on Moen.
    If you live in an area with hard water, you may need one.
    Feb 2008
    Ontario, Canada
    Terry, you just proved my point. Conditions are not the same throughout North America. And for someone to sit there and judge other peoples experiences for their areas is not a way to conduct themselves with the "know it all " attitude
    Default Moen
    Since I have worked on Moen "Dialcet" faucets since they were created, (I installed the first one in the Chicago area in my own bathroom), and have had innumerable ones that resisted extraction, to the point where I have four different pullers in my truck, and some extractions require more than one, I guess my 60 years of experience, (in Chicago, Michigan, and Arizona), tops your 30. Your area may be such that EVERY brass Moen stem comes out with the plastic device, but in that case I think it may be the exception. As I have stated, that "last resort" puller, if it does not work, means you replace the valve. And if that puller does not work, the plastic DooDad would be completely worthless. But if you noticed I said your comment was from someone who "never had a stuck cartridge", which could be true in your case.
  1. No hot water from Moen shower faucet
    By timwise999 in forum Shower & bathtub Forum & Blog
    Last Post: 09-06-2010, 08:09 AM
  2. Moen Valve won't stop dripping
    By Henry G in forum Shower & bathtub Forum & Blog
    Last Post: 05-10-2010, 02:38 PM
  3. No hot water on Moen Shower Faucet
    By CMWill46 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-07-2009, 03:29 PM
  4. Moen Shower Faucet Leak
    By rapah in forum Shower & bathtub Forum & Blog
    Last Post: 11-11-2007, 03:15 PM
  5. dripping single handle shower faucet
    By pkbertram in forum Shower & bathtub Forum & Blog
    Last Post: 09-20-2004, 11:38 AM
