Page 4 of 4 FirstFirst 1234
Results 46 to 49 of 49
Thread: Installing a Kohler Villager Cast Iron Tub
  1. #46
    What do the installation instructions say about it? The thing sits on the feet, is pretty heavy, but a ledger can ensure it can't tip a little.
  2. #47
    DIY Senior Member jch's Avatar
    Jan 2006
    Victoria, British Columbia, Canada
    Kohler's installation instructions say for the tub to sit on only its 4 machined feet.
    *However*, these feet are very skinny (<1/4" wide) and will sink into the floor unless placed on metal shims. Also, they are not necessarily in-plane with each other. The Kohler Villager I just installed had warped and its feet were 1/8" out-of-plane. Wobbly tub, leaky drain (eventually).
    I eventually used a ledger board (despite Kohler's instructions saying not to) and am glad I did. No wobble. No sinking into the floor. Rock solid.
    - John
  3. #48
    Jan 2006
    Quote Originally Posted by Why did I try this? View Post
    If I wanted a ledger would the cast tub need to be set in place and then marks put on the wall? Or would I measure based on the specs and put on a level board and set the tub in once?
    I found it was an iterative process because the tub wasn't exactly true. Used deck screws to temporarily hold the ledger in place while I checked the tub for levelness and wobbles.
    Such is the nature of cast iron manufacturing I suppose. These beasts slump slightly as they cool, making them slightly different than spec.
    - John
  4. #49
    DIY Junior Member Why did I try this?'s Avatar
    Aug 2012
    Wisconsin
    Do the drains have to be installed prior to dropping the tub in place? I have an opening to the drain pipe from underneath but it is small and covered with a bunch of other pipes.
    Thank you
