Page 1 of 4 1234 LastLast
Results 1 to 15 of 53
Thread: Installing a Kohler Villager Cast Iron Tub
    Default Installing a Kohler Villager Cast Iron Tub
    Installing or setting a Kohler Villager Cast Iron Tub.
    The Villager weighs in at 316 pounds.
    It's best to bring it in with two men.
    Four men would be okay too.
    Once it's in the bathroom, I can set it into the alcove by myself without help.
    I use a ledger board on the back wall, making sure it's level first.
    Leave the tub in the crate, it stacks easier that way, and gives you some nice hand holds.
    I like to center the tub at the hips, and lean it on my back. Then I have a guy or two hold the back of the crate and follow behind me.
    I carry it like I'm giving someone a piggy back ride.
    When I get it into the bathroom, I set it in vertically with the drain side down, with the open part of the bathing well towards the tub valve.
    I make sure I have two 2x4's with me.
    One, I place on the floor, this prevents the tub from falling all the way down, and can act like a pivot with the second 2x4
    The 2x4 on the floor doesn't have to be real long.
    After I pull the crate off, I can start letting the tub drop back against the back wall. With the crate off, it will pull toward the back wall, and catch on the studs.
    To get past the stud, I have to pull the tub toward me, and slid it by.
    Almost there.
    At this point, the tub has dropped down to the floor level.
    I leave a bit of drywall out on the room side of the tub on the end away from the drain.
    The apron will fall into that space.
    I leave a 2x4 on the floor to prevent the tub from dropping too far.
    If I need to lift the drain side of the tub up, I can use a second 2x4 and lever it up, using the 2x4 on the floor as a pivot.
    This way, I'm pushing down, and not lifting up.
    At the last bit, I pull the last 2x4 from below the tub.
    If the tub needs sliding in, I can sit on the floor, and use my legs to push it in.
    If the tub is in the room, I can set it by myself.
    Default tub
    WAAAAAAY too difficult. You are a glutton for punishment and a candidate for a bad back. It is also usually not possible to remove the drywall from the opposite side for a remodel/replacement installation. I use the "Egyptian pyramid" method, which employs as little effort as possible along with the maximum use of leverage.
    ON some tubs a 2x4 ledger is too thick and it hits the radius of the tub. For those, or if you are not sure, use a 1x4. As for getting it into the space. Lay the tub on the floor with the apron on the bottom. Get it into the approximate position. Remove the front, top, and back of the crate. Place "something" on the floor, (cardboard, or 1x2 strips, or anything similar to protect the tub edge), and slide the tub off the crate onto it.Then, depending on how large the recess is, either roll the tub down and onto the ledger, or angle it in between the studs on one end, then turn the tub parallel to the back wall and roll it down into position. When the tub drain is installed depends on your space. If you have access after the tub is in position, put it together last. Otherwise, assemble it on the tub, remove the assembly and put it into position while connecting it to the drain, then put the tub in place over it.
    DIY Senior Member DanMcD's Avatar
    Jun 2005
    Dayton, OH
    It is very hard for a novice like me to visualize the steps of this "Egyptian pyramid" method. I guess I'm a picture guy.
    Now I know that hj has been plumbing longer then me, and is very wise and cabable.
    But wait! Did he also work on the pyramids?
    I need to make him an avatar with a pyramid now.
    I'm sure that hj knows what he is doing.
    I would love to see him install one, old guys do it better.
    The way I do it, was from an old guy, but there are always many ways to do things.
    Now if we can only talk hj into posting some pictures.
    Some of the earliest history of the Pyramid comes from a Greek traveler named Herodotus of Halicanassus. He visited Egypt around 450 BC and included a description of the Great Pyramid in a history book he wrote. Herodotus was told by his Egyptian guides that it took twenty-years for a force of 100,000 oppressed slaves to build the pyramid. Stones were lifted into position by the use of immense machines. The purpose of the structure, according to Herodotus's sources, was as a tomb for the Pharaoh Khufu (whom the Greeks referred to as Cheops).
    Default tub
    Actually, it is almost easier to do it than to describe HOW to do it. IF the tub is going into a recess with a knee wall or other way that the tub can fit in front of the opening, then you START with the tub in the location of Terry's second posting, (otherwise you get the tub as close to the final location as possible, usually at an angle), but with the tub laying on the apron in the crate. You remove the crate except for the bottom piece the tub is on. Then you slide the tub out of the crate onto a couple of boards, 2x4's are best because they are the same thickness as the bottom plate of the wall. Then you toss the last piece of the crate away to get rid of it. If the tub is on an angle, you slide it forward so the upper edge goes into the space between studs. Then you rotate it square with the back wall. At this time your tub is at the recess, between the two walls. Then you gradually rotate it downward onto the ledger board. If you have it is the right position to start with the tub will hit the rear studs before reaching the ledger. Then you can let go of it and get your hands out of the way. The tub will continue down by itself, or you can push it if necessary. Now all you have to do is jack the front up a bit and remove the two boards. With a two wheel hand cart to move the tub into the room it is a one man job. In fact two men might get in each other's way.
    DIY Senior Member Andrew21's Avatar
    Jun 2006
    New York
    WOW, this is very helpful.
    I just got my grandmothers house and will need to replace the tub. I'm thinking if I can go with the cast iron or the steel tub. I'd rather the cast iron though. I do have a problem. Where the tub sits if you look down the bathroom, its in a recess on the right hand side. Not a problem but right next to it is a radiator. Its one of those where you have to pull the front of it off to access anything inside of it. Well the radiator is in the way. Anyway I can remove it temporary and put the tub in..or will I have to do it your way but sideways?
    I'll take a picture to show everyone. Easier to explain.
    Default radiator
    A picture would help because how you can install the tub depends on exactly where the radiator is and how far it projects into the room. Normally it would not be a problem.
    Jun 2006
    New York
    Here you go. Just a reminder, this is my parents home. The house I inherited from grandma is exactly the same. Same builder back in the day. Only difference is that there is tile in her bath instead of carpet.
    Default heater
    The heater does not cause a problem with either method of installing the tub.
    Jun 2006
    New York
    HJ,
    So here's what I'm going to do. let me know if I'm doing this wrong.
    When the old tub is out and the new one goes in, we're going to do the following:
    -Take the tub and lay it down sideways.
    -Take the wooden crate packaging off on the sides and the top or just take everything off
    -Slide the tub in on an angle and hopefully it will fit.
    -Proceed with the rest of the steps to lowering the tub down (assuming the ledger board has been set. Then putting in the drain.)
    Now I see a problem when trying to angle the tub in. It just barely fits. If we can't get the tub to angle in, are we going to have to lift the tub up and around the radiator. Know what I mean?
    Thanks for your help
    Andrew
    Jun 2006
    New York
    After thinking about this, I think that this may work. When the time comes, I'll let everyone know. Thanks again.
    DIY Junior Member tbb2's Avatar
    Feb 2009
    Arlington, Virginia
    Default rotating into place retrofit 5 foot niche tub
    I have a typical 5x8 bathroom. The door opens on the narrow end and the tub is across the opposite wall.
    I was thinking of replacing the tub but haven't figure how the new tub could be brought through the door and rotated 90 degrees to fit on the opposite wall.
    The narrowest diagonal dimensions will be longer than the side walls by approximately 2" - so the walls obstruct the turn. (?)
    - My best guess is that it rotates into the stud cavity but at 16" high it does not fit between standard stud spacing.
    Also ...
    How can the weight of a cast iron tub be handled so that it can be lifted and set back into the niche?
    Any tips on moving a cast iron tub in close quarters?
    Sep 2009
    Seattle. WA
    You stand the tub on end and let it rotate into place. Takes 3 or 4 reasonably fit people to manhandle the thing.
    with the radiator there, you uncrate the tub then angle it into the alcove with the left edge between the joists. Then rotate the right side in so the tub parallels the back wall. Pull the tub forward as far as possible, the push the top away from you so it starts to settle into position. It will probably hit the rear wall before it is all the way down, so you will have to pull it forward a bit, unless the weight of the tub does it for you. After you do it for 60 years and many tubs, it will be easy for you.
