Results 1 to 13 of 13
Thread: Smell coming from kitchen sink
    Default Smell coming from kitchen sink
    HI:
    Having returmned from vacation, we found a foul smell coming fro the kitchen sink . Smells like rotting plants. I have tried draino foaming liquid, draino crystals but the smell is still there. I was wondering what could be the cause and how to resolve it.
    DIY Senior Member thezster's Avatar
    Jul 2005
    Fort Collins, Colorado
    Depending on how long you were gone... the trap may have dried out, letting sewer gases come out of the drain...
    Is it draining properly? If it is, and it were me - I'd pour a good slug of bleach into the drain and let it sit for an hour or so before washing the concoction down thoroughly.
    Also, is the garbage disposal on that drain too? You might have some crap stuck in the teeth.... I throw a couple of handfuls of ice into the unit once in a while and crush it with the disposal followed by a good flush of hot water - it seems to clean things up pretty well.
    If it's not draining properly, you've obviously got something stuck.
    Either way, you should be able to disconnect the p-trap under the sink and clean it out thoroughly with a flexible bottle brush or similar tool.....
    It's 9a.m. Let's have a beer!
    Quote Originally Posted by thezster
    Either way, you should be able to disconnect the p-trap under the sink andclean it out thoroughly with a flexible bottle brush or similar tool.....
    Forgive my ignorance but what is a p-trap
    Jul 2005
    That would be the "loop" - U shaped - under your sink. It should be held together on both ends by compression fittings, which are easily unscrewed (by hand pressure alone)... disassembled, cleaned, and put back together...
    It holds a small amount of water constantly to keep sewer gasses from coming up through your drain. It can dry out if left unused for an expended period of time.... It also catches heavy sediment and traps it there...
    Thnx for the info, I wil try to clean this out as suggested.
    Tradesman Plumber Kristi's Avatar
    Jan 2005
    Vancouver, BC
    I stongly dislike using all those chemicals to try and unclog your drains or to "freshen" them up. They're highly corrosive and do no favours to your system. I probably get a little more excited about them, because where I live, we seem to think it's alright for the city to dump our waste straight into the ocean with only one stage of treatment (basically having a catch/pit for collecting the biggest and heaviest of solids). Go with thezter's recommendations and pull that puppy apart on your own - the P trap that is. I bet what you'll find is that it's quite clean and required a good flushing. And nothing... almost nothing... can compare to rancid bits of food stuck in your garburator for a couple of weeks. If you have one, I bet that's your culprit. Feel free to toss a lemon 1/4 piece at a time along with that ice treatment...
    sorry about the soapbox moment guys
    Plumber plumber1's Avatar
    Aug 2005
    Florida
    Default smell
    I agree with kristi............lemon
    General Contractor Carpenter toolaholic's Avatar
    Jul 2005
    Marin Co. Ca.
    Default we don,t know if 2 wire is on a septic system
    bleach wouldn,t be his best friend?
    Jul 2005
    "Treehuggers"....
    Actually, you guys are right on..... and I don't know why I didn't think of it.... water with a slice of lime is our drink of choice in our house.... and lots of limes get sent down the disposal..... and it never smells....
    No, I'm on the city water/waste system. I don't have a garbage disposal but I feel that it probably is food stuck in the p-trap as mentioned in an earlier post.
    I will try to clean out the p-trap or replace if necessary and see if this recitifies the problem.
    Jul 2005
    With all the ecologically "sound" advice.... going around..... let us know how it turns out....
    DIY Junior Member hwebb78's Avatar
    May 2010
    Ocoee, FL
    Quote Originally Posted by thezster View Post
    Time to crack open an old post LOL
    I'm having the same issue here, the plant smell...doesn't smell like sewage, smells like a head of lettuce is stuck in my kitchen sink drain. I have double sinks, and the smell is coming from the left sink, I don't have a disposal either. I ran bleach down the drain, and still nothing...did anyone find a solution to this?
