Results 1 to 2 of 2
Thread: Bathtub drain crisis!
    DIY Senior Member miamicanes's Avatar
    May 2009
    Pembroke Pines, FL
    Default Bathtub drain crisis!
    Ack! My friend's here to help me install it, and I just realized that the drain includes a thick foam ring (for the overflow) and a thin rubber ring (for the drain). Do I still use plumber's putty, or do the rings take its place? The overflow foam goes behind the opening. The bottom drain ring appears to go between the upper side of the drain hole and the ring.
    DIY Senior Member Nate R's Avatar
    Jan 2007
    Milwaukee, WI
    No putty on the foam overflow gasket. The rubber gasket goes underneath the tub, between the drain shoe and the tub. Plumber's putty will still go between the top part of the drain at the tub. (The silver part of the drain that is on the floor of the tub gets putty underneath it.)
