Results 1 to 3 of 3
Thread: Old Existing G.E. Circuit Breaker Panel
    DIY Member Ford2001's Avatar
    Sep 2009
    Manchester, Vermont
    Cool Old Existing G.E. Circuit Breaker Panel
    Can and would you use QO SD Homeline circuit breaker in a G.E. panel.
    The panel has a 100 amp. main disconnect.
    The breakers in the G.E. panel are only going to be temporary, during the contruction
    stage.
    After which, a new panel will be installed in a new location, with the
    existing G.E. panels being remove.
    Network Engineer rmelo99's Avatar
    Jul 2006
    Short answer is NO.
    That being said there are cross compatible breakers for some panels. Certain GE panels can take certain Cutler Hammer breakers.
    As far as SquareD is concerned even their QO and HOMELINE breakers aren't interchangable! What makes you think they would work in a GE panel?
    Sep 2009
    Manchester, Vermont
    Cool Homeline breaker in a G.E. panel
    rmelo99 to your reply to my thread
    Didn't know, that why I put this thread in.
    Thanks for your answer. Now I know they will not work.
