Results 1 to 7 of 7
Thread: Drain size for tub/shower combination
    DIY Junior Member
    Nov 2009
    Vacaville, CA
    Default Drain size for tub/shower combination
    I am reading that the tub drain should be 1 1/2" while a shower drain should be 2". If a tub/shower combo is installed, can a standard tub drain be used, or does that require a larger shower drain?
    Dec 2005
    SW Florida
    What do you mean by tub/shower combo? Tub with a shower head? If so the 1-1/2" drain will work. The idea is that the tub can provide holding space for water if the drain is slow, a shower doesn't offer much if any holding before you overflow the curb.
    Matt
    Enjoying life in SW Florida
    The smaller size drain works.
    It also works for showers too, and that used to be the size required by "Code" too. I think that bigger houses and longer distances are the reasons why its size was increased to 2".
    Quote Originally Posted by FloridaOrange View Post
    .... idea ... holding space for water if the drain is slow, a shower doesn't offer much if any holding...
    Journeyman/Inspector Inspektor Ludwig's Avatar
    May 2006
    In the good ol' UPC
    Yes, you can have an 1 1/2 drain for tub/shower combo.
    Default 1 1/2"
    You are too young to remember when a shower was permitted to have a 1 1/2" drain. I am also.
    Dec 2005
    SW Florida
    Florida used to require all under slab plumbing to be minimum 2". Now they don't, along with allowing CVPC (with joints) underslab....
    Matt
    DIY Junior Member plumbergreg's Avatar
    Jun 2009
    Ontario, Canada
    Quote Originally Posted by geniescience View Post
    The sizes in the code are the minimum size not the required size
    Plumbing shop Supr.
    My plumbing hobby site PlumbingHelp.ca
