Results 1 to 6 of 6
Thread: Landlord seeking advice on new water tank
    DIY Junior Member
    Nov 2009
    Chicago
    Default Landlord seeking advice on new water tank
    Hi all,
    I'm a landlord of a 4 unit building, and am considering options for a new hot water tank. I'm considering AO Smith Vertex, Rheem and Bradford White. The Vertex if very efficient and I believe it qualifies for a tax credit. However, I am concerned as I have heard negative reports about AO Smith quality ... not sure if this applies to the newer Vertex.
    If anyone could give me any feedback or advice, I would be really grateful.
    Dale
    Yakima WA
    Most of the pro plumber on this forum recommend the Bradford White or GE/Rheem.
    Default heaters
    IF you visit the various supply houses you will find about the same number of AO Smith heaters have been replaced as any other brand. Some Bradford White's have very short lifes, (at least one BW I know of lasted just one day), just as the others do also. It is a function of usage and manufacturing situations that the manufacturer CANNOT control which cause the failures, so you throw the dice NO MATTER which make or model you choose.
    We've installed many Bradford White and A.O. Smith water heaters throughout the years. I see nothing that warrants me believing that either one of them is a better water heater than the other. This year we only had 2 call backs on A.O. Smith water heaters out of over a hundred jobs.
    A.O. Smith always warranties and stands behinds their water heaters, but then again, I could say the same for Bradford White. i see no basis for one being better than the other.
    Plumbing Solutions, LLC
    Your Local Plumber in Columbia, S.C.
    Default heaters
    I deal in Rheem, Ruud, AO Smith, American, and Bradford White, mainly and do not find ANY appreciable differences in any of them.
    In the trades Dana's Avatar
    Jan 2009
    Is this a single tank to serve 4 units, or do they all separate heat/hw systems?
