According to the site these studor AAV's are a replacement for a open pipe system, but I do see what you mean about not allowing air out - and if I understand the problem correctly, I've airlocked the pump tank behind all the water trying to get in - so I need a way to let the air out of the tank so the water can get in to trigger the pump. (When I sucked the water out of the sink it lowered the pressure enough that the air was then able to force itself back through the sink trap and break the seal right?)
So if this is the case and I actually had a proper open air vent then it would work - even though I've not vented the p trap after the washer? Or would venting the line as here
http://www.woosworld.net/images/base...02-addvent.JPG
Allow it to work with the AAV in place? Is there a way to correct what I have short of taking off the AAV and making a vent to my roof? (This does not excite me at all!)
Another thought - I happen to be right below the kitchen sink (which if I understand the terminology is wet vented as there is no separate vent line) - could I tie my vent line into the kitchen sink and it would then share the wet vent? I'm not sure this makes sense or works, but I've seen several places where the talk about tying into another sink to make things work so I'm not following how.
