Results 1 to 6 of 6
Thread: Basement floor
    DIY Member idoc4u's Avatar
    Sep 2009
    Indiana
    Default Basement floor
    Does anyone have a recommendation regarding the type and number of bag mix of concrete best used to fill and finish a basement floor after having cut the original concrete floor to relocate DWV PVC?
    Thank you.
    Default concrete
    Bags of "pre mixed" concrete. Use a many as necessary for the hole size.
    Sep 2009
    Indiana
    Default Thanks hj!
    hj,
    Thanks for the recommendation.
    I was overthinking, I guess.........idoc
    It's best if you drill some holes and insert some rebar to anchor the new and old concrete together. A couple of stubs on each side of the hole and maybe more, depending on the size of the hole is a good idea to tie the old to the new.
    Jun 2009
    Penticton, BC
    Quote Originally Posted by idoc4u View Post
    hj,
    Measure the volume of concrete you'll need and buy the # of bags needs to fill that much volume.
    L*W*H
    Sep 2009
    Indiana
    Default thanks again
    Thanks again, guys....idoc
