Results 1 to 6 of 6
Thread: Battery Back-Up Sump Pump
    DIY Junior Member
    Sep 2009
    Madison, WI
    Default Battery Back-Up Sump Pump
    I was wondering if anyone had a recommendation for a battery back-up sump pump? Is the basement watchdog a good pump?
    Union plumber/pipefitter-self employed Garydaplummer's Avatar
    Jan 2008
    Mechanicsburg, PA
    Default Tried them
    I've tried a couple of the Basement Watchdog backups and they seem to be good units. I would only use their battery backup though and not their main sump pumps. My preference after installing a few of these systems is the setup made by Zoeller. I trust their sump pumps and they make a nice battery backup system.
    DIY Junior Member
    Sep 2009
    Madison, WI
    Thanks for your help!
    DIY Member SemiHandyRon's Avatar
    Nov 2009
    Fairfield, OH
    I've had a Watchdog for several years. Flawless operation.
    Nov 2008
    Chicago, IL
    I recomend the Basement watchdog Big dog unit. http://www.basementwatchdog.com/base...dog_bigdog.htm
    DIY Junior Member rainstorm's Avatar
    Aug 2010
    Illinois
    Quote Originally Posted by Garydaplummer View Post
    Do you have any experience with the Pro Series ST1033 as a main pump? I thought I read someone's post that these are not the best and to go with the Zoeller. Also, do you know what the difference is between the retail version of the Basement Watchdog (Big Dog) vs. the pro-series PHCC-2400 besides the dual float? I am having a hard time deciding between the two.
