Results 1 to 5 of 5
Thread: Drain pipe size
Threaded View
    DIY Junior Member DMP's Avatar
    Nov 2009
    Phoenix
    Default Drain pipe size
    I am redoing my Master Bath. I removed the tub and shower and going to replace it with a two head shower, I was going to use the tub drain but it is only uses 1 “. If I use the shower drain that is 2” I need to move it 8’. (See Attachment)
    My question is having a vent that is 10’ from the drain will it cause problems with the p trap?
    Should I add the second 1 ” pipe (See Red dotted Line) just to make sure I do not have any problems?
    Thank you for your help
    DMP
