Thread: Converting Surface Mount Panel to Recessed?
    DIY Senior Member Nate R's Avatar
    Jan 2007
    Milwaukee, WI
    Default Converting Surface Mount Panel to Recessed?
    My main panel is currently surface-mounted to an interior wall in our back porch with the feed from the meter coming in through the backside.
    Can I add lumber over the existing wall, re-run the wiring through the new lumber, while keeping the box in place, essentially making what was a surface mount box a recessed box? I'd like to be able to hide what would be exposed wiring in a wall, as the back porch area will eventually be visible from the kitchen.
    What code sections do I need to be looking at that deal with this specifically?
    Electrical Contractor jbfan74's Avatar
    Jun 2007
    Newnan, GA
    Not a problem.
    Yes I am A Pirate-Jimmy Buffett
    As long as the panel is within 1/4" of the finished drywall you are good.
    Also, it would be easier to notch the lumber around the existing wiring.
    Jan 2007
    Milwaukee, WI
    Quote Originally Posted by 220/221 View Post
    Duh, didn't think of notching it! It's only there to hold up wallboard, so it doesn't need much.
    Thanks for the help!
