Results 1 to 4 of 4
Thread: Pressure regulator only lasts a year or so
    DIY Junior Member gplouffe's Avatar
    Nov 2009
    poway ca
    Default Pressure regulator only lasts a year or so
    I have had to install a repair kit every year or so (sometimes less) as the pressure (about 40psi) starts to creep up slowly until reaching street pressure (95psi or so). When I disassemble the regulator there is plenty of corrosion on the diaphragm spring etc. and quite a bit of calcium build up. The seat gasket has a typical ring mark where it hits the seat (seat feels smooth), some slight calcium build up on it (gasket) as well. My question is, how long should a typical rebuilt regulator last before having to rebuild? I am thinking I having to replace the kit way too often. Thoughts?
    Guy
    Default Prv
    I DO NOT rebuild pressure regulators, usually for that very reason. It is cheaper for me to replace them with a good unit that will not fail in a year.
    Nov 2009
    poway ca
    Thanks for the rapid response. This model is a Wilkins 600, I have replaced completely one time in the past, lasted about 2 to 3 years before failure. Is there a better model that you would recommend?
    Guy
    Jun 2009
    Canada
    I replaced my faulty regulator with a Watts 25AUB-Z3 3/4" haven't had a problem with it.
    (2x4 brace was burnt previously, not by me)
