If the trap arm is pitched right, and the pop up comes up high enough to drain fast enough, and you run the water full blast for a few seconds after your done to rinse out the trap...you shouldn't be having to do that...
I have a sink we always brush our teeth at and it gets a crud build up and I have to take it apart to clean it. Any super drain cleaner that will get this stuff out? Drain is all ABS pipe, 1-1/4".
