Thread: Broadway Faucet - HELP!!
    DIY Junior Member rweatherdon's Avatar
    Nov 2009
    Delaware
    Question Broadway Faucet - HELP!!
    I have a customer who has Broadway faucets in each of her 7 bathrooms!!!. They are the wide spaced ones with seperate hot and cold valves with L type handles. I need to repalce three cold cartridges, which I think I have finally found parts for on the Net. BUT - - I have no idea how to get them apart!! Does the L handle unscrew, or what ??? There is no obvious cover to remove that might reveal a screw. The L handle just goes into a round ball that sits on top of the outer cone shaped trim cover. Any suggestions would be appreciated.
    Thanks Ray
    Plumber jimbo's Avatar
    I have some diagrams , and they are not real clear, but it appears that the bell-shaped trim unscrews off the valve body. Proceed with caution, because it is somewhat of a miracle that you may have found stems. Any body parts will NOT be available. At some point, you will just have to suck up the fact that you are left with dinosaurs which have to be replaced.
    Ingersol-Rand is still trying to cover warranty issues for the original purchaser, but even with them, I think parts other than stems are scarce to non-existent.
    Default faucet
    Depending on their age, they could have small allen screws holding them but they may not be visible until the faucet is turned on all the way.
  1. Shower faucet, what brand? Broadway collection
    By Terry in forum Shower & bathtub Forum & Blog
    Last Post: 08-09-2013, 01:45 PM
  2. Broadway Faucet problems
    By oakalley in forum Shower & bathtub Forum & Blog
    Last Post: 07-22-2009, 07:05 PM
  3. Broadway faucet
    By Dependable in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-24-2009, 07:18 AM
  4. Broadway Aerator
    By mike802 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-24-2008, 03:47 AM
  5. broadway collection
    By ronc in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-12-2007, 06:18 AM
