Actually, problem #2: the instructions on the Gatorbite fittings never actually tell you exactly how the tube liner is supposed to go in. I've kind of figured out that it goes in flange first, but I'm still trying to figure out whether it just sits inside, or whether I'm supposed to work it past the first point of resistance so it sits behind it in what appears to be a ring-shaped depression beyond it. Argh
^^^ Update: you stick the liner into the PEX, then stick both into the fitting.
