woodsdancer
- Messages
- 11
- Reaction score
- 0
- Points
- 0
Gary Slusser said:I take it that the air is vented at the kitchen sink somehow. ...Hopefully Woodsdancer will explain how the air is vented.
Gary
Quality Water Associates
wow, I had no idea my setup was so unusual (or perhaps that my understanding was so bad)... but let's see what else I know (or think) I can tell you.
yes, I'm in vermont... snow country from november through April. Freeze is a serious concern
the pressure tank is located in a cupboard in the kitchen. It's at the presure tank that I hear the hiss when the system quits. That is why I say the air flow is from the kitchen to pipe (better to have said "near the pressure tank to pipe"). I had just assumed that actual valve was at the tank, not in the well and that the hissing I hear comes from that valve.
I hadn't thought about the fact that there must also be a venting out (to kitchen or somewhere) of that air when the pump starts up (there is no noticable hiss at that point, although the tank does make a fair bit of noise, that I would describe more as gurgling than hissing).
The time that I hear the loudest hiss of that flow is when the well quits. (I can hear it then from the next room -- and usually run to shut off the water.) There is often just a very faint slow hiss when there is no apparent water activity in the house. That part I don't understand at all.
And the original posting came from what seems to me (or is it wishful thinking?) that my problem is associated with rapid draw down more than total water use... and wondering is the drain back valve (with it's loud noise at thatpoint) could be related to that.
