woodsdancer
- Messages
- 11
- Reaction score
- 0
- Points
- 0
Hi
I have a well, which sporatically gives me strange problems -- which I *think* may be connected with the drain back valve: it acts as if I am out of water, but with no apparent reason.
I think the well itself is about 90 feet; submerged pump. The pressure tank has a drain back valve because the intake pipe runs over ledge close to the surface.
The symtom I experience is that periodically I run out of water for no apparent reason -- this morning after one shower and two toilet flushes; this on a system that one day last week washed three loads of clothes, and, heck, it even rained all day two days ago. When the water stops, I hear the drain back valve hissing ... for a long time (in fact that is usually the thing that first attracts my attention).
There is a lever on the switch to force the punp to run even when the pressure is too low. and sure enough, the well does not produce any water. Usually in a couple hours I can use water again at full speed, but in the mean time, no water.
Can something other than low water level be causing this problem?
Thanx for any ideas
Thanx for any ideas
