Results 1 to 5 of 5
Thread: Slant Fin Sentinel Boiler not Fireing
Hybrid View
    DIY Junior Member Ironwalker's Avatar
    Nov 2009
    NYC/NJ
    Question Slant Fin Sentinel Boiler not Fireing
    Hi folks, nice forums.
    Seems my boiler will not start up anymore.
    I had it working fine for 3 days, then it got warm and I lowered the thermostat down so it was off, but, now it wont fire.
    I hear the clicking and the water running when turning up the thermostat, but it never fires. The pilot light is off and does light when I manually light it but it wont stay lit. Yes gas is on.
    I do not know if it is an always on pilot light or the one that lights by sensor when needed. Anyway to tell?
    It will be getting down low forties tonight and being a do it myself type would like to know where to start to diagnos the problem, any ideas would be greatly appreciated,
    Thank you
    It sounds like you have a standing pilot light. The burner won't light unless the pilot is lit. The pilot won't stay lit unless the sensor that sits in its flame says it is lit (i.e., it gets hot, and sends a signal to the gas valve). So, first, make sure that the sensor is in the flame of the pilot. It might also be dirty, so clean it off, or reposition it if required so it is in the pilot flame. If that doesn't work, if you have a multimeter and the manual, you can test the sensor (thermocouple) to see if it is within specs. If not, you'll have to replace it.
    Nov 2009
    NYC/NJ
    I have a fluke meter I use from my auto mechanic days.
    The manual is handy as well.
    What should I test (amps,volts,ohms) for and will the manual give me the proper stats to go by? Usually that stuff isnt in the owners manual.
    Thank you
    Nov 2009
    NYC/NJ
    Woah thats me in the avatar!
    Kind of, thats my profession.
    Love it thanks.
    Ok, thermocoupler is bad, new one is around $10 so I will get a new one and see if that helps. My neighbor does this for a living and keeps the company truck at home, he may have one on the truck, if not we have a great supply store on the main road.
    DIY Junior Member julio.caluori's Avatar
    Oct 2009
    Montreal, QC
    Let us know how it went !
    Good luck
  1. Slant / Fin Electric Boiler Chattering
    By densmper in forum Boiler Forum
    Last Post: 01-09-2013, 06:41 PM
  2. Brand New Sentinel boiler problem - help please?
    By corrypaw in forum Boiler Forum
    Last Post: 11-16-2011, 05:26 PM
  3. HD Slant/Fin
    By rockycmt in forum HVAC Heating & Cooling
    Last Post: 12-14-2009, 11:18 AM
  4. Slant coil problem
    By matt74 in forum HVAC Heating & Cooling
    Last Post: 10-16-2008, 04:44 PM
  5. sentinel wall heater fans won't turn
    By qkrinkle in forum Remodel Forum & Blog
    Last Post: 09-17-2006, 11:04 AM
