Tanks are often tipped a little on purpose and the pickup line is positioned away from the lower end of the tank. Water will accumulate at the low end, and the pickup line would normally be up off the bottom of the tank at least a few inches. Moisture is usually present in an oil tank but shouldn't be much and should not be getting picked up. I would immediately inpsect the filter for signs of rust or water. You could remove the line from the inlet side of the filter and draw some fuel out of that line with a small hand siphon pump. I use one often at work and they are sold for less than $15 in various stores. I use it to prime diesel engine fuel systems and other uses. If your filter is clean and you are able to draw clean fuel from the line, your problem is with the furnace. Might need a nozzle or an adjustment on something. I have an old oil burner in my garage.....Thanks to it's quirky nature...I learned all about oil burners. I also take care of a 350,000 BTU waste oil furnace at work and it can keep me occupied for hours during the colder months doing various maintenance chores to keep it operating.......The fuel system is in need of cleaning often but that is understandable as it burns dirty oil......
