Results 1 to 5 of 5
Thread: how to refill and hot water system
    DIY Junior Member chuckdiy's Avatar
    Jan 2010
    MA
    Default how to refill and hot water system
    I have a pumped hot water monoflow system with 8 convector radiators. I'll be draining the system so that I can move some of the existing pipes around. Draining the system seems pretty straight-forward to me (but if anyone has any tips, I would certainly appreciate them). However, I don't know what the process is for refilling the system? How to I make sure all of the air is out. Can someone help?
    I'm thinking that I would just open the bleeders on each of the convectors then start to put water into the system. Then just wait until each of the bleeders spews water. Is that effective? There is an Air Scoop on the system, but I don't know how much air it is designed to remove. I should mention that I don't think the expansion tank has a bladder in it (old style)....it's a system that was done in 1960. Do I have to do anything with the Air Scoop during the process?
    Any and all help is much appreciated!
    Previous member
    Jul 2009
    North of the Mason dixon Line
    yep, that's it
    Jan 2010
    MA
    Thanks. One follow-up. Do I have to emty the expansion tank during (or before) this refill process?
    Aug 2009
    South*East
    No you don't have to empty the tank but as long as you have the system down it would be a good time to drain it. It should be done yearly.
    John
    DIY Junior Member
    Feb 2010
    New Delhi
    I was also looking for the same for a long time but still unable to find the right advice.
    I didn't found any useful insight in other forums. Well you can look at it http://advice.thisoldhouse.com/showthread.php?t=1245.
    If it helps you?
