Not doing it myself... cost of water to refrig
Status
Not open for further replies.
Mntentman
I don't like messing with much plumbing other than working under the sink, so I need a pro for this. I need to run water to a new refrigerator, have never had one with water. The kitchen sink is not on the same wall. I know there are a lot of factors involved, but any way someone could give me a ballpark estimate as to what a plumber would charge for this? Thanks.
WHere is the nearest cold water? It could be a bathroom, the basement below, or the kitchen sink. What you don't want is one of the clamp-on valves that then pierces the pipe to supply the water. You want to install a T and a real valve. It will all depend on where it is, how far you have to run it, and how good the access is.
Mntentman
The basement underneath is open, so access there is very easy, and there is a bathroom and a kitchen sink both no more than 15 feet from the refrigerator, so lines are near.
Gary Swart
Yakima, WA
It is impossible to even hazard a guess on plumber or electrician charges because every job will depend on ease of access which will determine the time needed, and local plumber/electrician rates. It's not a difficult job nor should it take very long barring access problems. Materials are a minor cost, and as Jim suggested in his reply, insist on a ball valve rather than the saddle valve that just punctures the supply line. That will cost a bit more, but it is a much better way to make the connection.
water
The cost would even depend on the plumber's efficiency or experience. One might make a half day project out of it, while another would have it in and running in a half hour or so.
Status
