Thermostats : Dual Element in a Single Element Water Heater
Synicasm
Oregon
Is it ok to use a Dual Element Thermostat on a Single Element Water heater by just not hooking anything up to the "lower thermostat" connections ?
WorthFlorida
Solutions
Orlando, Florida
Why do you think you need a new thermostat? Always change parts with the right/correct part.
JohnjH2o1
Florida
I would use the upper thermostat. If you use the lower you will have no protection for over heating.
John
PS woethflorida I didn't see that you changed your post recommending using the lower element.
thermostat
Find a "solar water heater" themostat. It is for a single element and has the required ECO, but is less expensive than the SPDT upper thermostat. But otherwise, it is okay to use the upper one as long as you connect the element to the "upper element" terminals.
WorthFlorida
Solutions
Orlando, Florida
At first I did say a lower thermostat but then I realized that it does not have a built in circuit breaker. I "edited" my first comment.
