Results 1 to 5 of 5
Thread: Thermostats : Dual Element in a Single Element Water Heater
    DIY Junior Member Synicasm's Avatar
    Nov 2009
    Oregon
    Default Thermostats : Dual Element in a Single Element Water Heater
    Is it ok to use a Dual Element Thermostat on a Single Element Water heater by just not hooking anything up to the "lower thermostat" connections ?
    DIY Member WorthFlorida's Avatar
    Oct 2009
    Lake Worth, Florida
    Why do you think you need a new thermostat? Always change parts with the right/correct part.
    Aug 2009
    South*East
    Quote Originally Posted by WorthFlorida View Post
    I would use the upper thermostat. If you use the lower you will have no protection for over heating.
    John
    PS woethflorida I didn't see that you changed your post recommending using the lower element.
    Default thermostat
    Find a "solar water heater" themostat. It is for a single element and has the required ECO, but is less expensive than the SPDT upper thermostat. But otherwise, it is okay to use the upper one as long as you connect the element to the "upper element" terminals.
    Oct 2009
    Lake Worth, Florida
    At first I did say a lower thermostat but then I realized that it does not have a built in circuit breaker. I "edited" my first comment.
