Results 1 to 6 of 6
Thread: Can I concrete around ABS?
    DIY Junior Member manintrees's Avatar
    Nov 2009
    Squamish, BC Canada
    Default Can I concrete around ABS?
    I am building a bathroom in an unfinished basement and have removed a chunk of the slab to put in a shower and toilet. I have roughed in the plumbing and was wondering what I should do when it is time to pour the concrete. Should I wrap the ABS in something so the concrete doesn't contact it? Thanks for your time!
    Default Abs
    Some areas around here want it tape/wrapped, but most do not. I have NEVER wrapped any ABS risers coming out of the concrete.
    Nov 2009
    Squamish, BC Canada
    Thanks a bunch. This is a great site!
    Architect Spaceman Spiff's Avatar
    Salt Lake City, Utah
    I usually wrap in a layer of that thin foam "sill seal". It allows me to jackhammer the concrete out if I need to and allows for expansion/contraction when it gets hot/cold. One inspector I dealt with required it...
    Spaceman Spiff aka Mike
    Previous member
    Jul 2009
    North of the Mason dixon Line
    Yep, either sill seal or they make a cap called a red had that keeps the concrete away from the pipe.
    Nov 2009
    Squamish, BC Canada
    What a weird and fortunate coincidence. I assumed that something was needed so I wrapped the pipes in sill gasket a few days ago. I posted the thread to see if that would suffice. Thanks guys.
