Results 1 to 5 of 5
Thread: Floor-Mount Rear-Discharge Guidance
    DIY Junior Member
    Nov 2009
    tucson
    Default Floor-Mount Rear-Discharge Guidance
    I've reviewed and re-reviewed the reviews and am now looking for guidance from someone in the know...
    What would you recommend for a floor-mount, rear-discharge, elongated-bowl, watersense-approved toilet?
    Thanks for your suggestions!
    You could use a Gerber 21-310 with the 1.1 gallon tank.
    Do not get the dual flush tank. They quit working in six months.
    DIY Junior Member
    Nov 2009
    tucson
    Default re: Floor-mount, rear-discharge guidance
    Thank you - this seems to nail it.
    Am curious -- why recommend the 1.1 over the 1.6? Is there a bowl clean advantage to either? (will be an issue with my wife). Also, Are both considered Watersense approved?
    Thanks again for your help - very much appreciated.
    The 1.6 tank is not Watersense approved.
    The 1.1 is.
    Do not get the dual flush tank. They quit working is six months.
    For what it's worth, the 1.1 gallon tank Gerber uses is a variation of the dual flush using the same tank and handle/actuation mechanism. The only difference is that it's a single flush with reduced volume.
