Results 1 to 9 of 9
Thread: Set cast iron tub in mud??
Hybrid View
    DIY Junior Member
    Nov 2009
    Kansas City
    Default Set cast iron tub in mud??
    We are remodeling our 2nd floor bathroom and have purchased a 72" Toto cast iron tub. The tub will be placed in the corner of the room and our carpenter has built a surround and a plywood base. The subfloor is in good condition.
    Our plumber intends to place the tub in a bed of cement mud but I have heard it's better to place shims under the feet instead. What would you recommend? I appreciate if several of you experts can respond as I need to get advice quickly. The tub goes in on Monday!
    Aug 2009
    South*East
    If the tub has legs that's what I would support it by.
    John
    DIY Junior Member Grimace's Avatar
    Oct 2007
    Slater, Iowa
    I would think that the mud would help distribute the weight over a larger area.
    Aug 2009
    South*East
    Why would Toto put legs on the tub if not to support it? It will also be supported by the rim.
    John
    DIY Junior Member
    Nov 2009
    Kansas City
    Default Toto says
    The installation instructions from Toto say do NOT support the tub by the rim. If we use a mud bed, how will that help level the tub? The tub weighs over 300 lbs - wouldn't it just sink to the bottom of the mud bed?
    Plumber Cass's Avatar
    Nov 2005
    Yes it would just sink...shim with composite shims...
    What does the instructions say about leveling...probably to place it on a level floor....
