Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: Receptacles far back from the wall
    Jul 2007
    USA
    Default Receptacles far back from the wall
    Some of my receptacles are a little far back in the wall, such that the faceplate requires longer screws (half inch instead of quarter inch). The receptacles are just flush with the face plate.
    Can I remove the snap off yokes on the receptacle and use them as washers to bring each out a little?
    My receptacles are installed in metal boxes with 1/2 inch mud plates. Strangely the drywall appears to be half inch too.
    Dec 2006
    They make spacer for that - even the Box Stores carry them.
    They come in a strip, like this:
    You tear off how many you need, they snap together to make it as thick as you need.
    3-4$
    Master Plumber Mark:
    do not hit your thumb...
    __________________
    A second concern is that you may want to get box extenders. These also come in various thicknesses . I know I've bought some at HD. They come with longer screws to hold the device in the box (but they sometimes fall off and you have to dig them out of the bottom of the box!). They're basically a fire/electrically neutral plastic ring in various thicknesses. The box should be even with the wall surface for safety. If you used those, you wouldn't need the spacers mentioned. They're pretty cheap.
    Dec 2006
    Good point.
    If the face of the box / mudring is recessed more than 1/4", you need to extend it.
    I'm getting sloppy on code, on here, lately... tsk, tsk.
    __________________
    No. You want the yoke to sit on the drywall to keep the recep/switches secure. Ideally they are flush. Legally you get 1/4". 1/2" back is not that unusual.
    If the drywall is cut too big for the yokes to sit on, use some nuts as spacers.
    Jul 2007
    USA
    Thanks for the tips. It looks like the receptacles are about one quarter of an inch back but the drywall has worn on some of them which makes securing the receptacles tricky. I think the plastic extenders will work nicely.
    I think I'll tidy up the drywall with some patches too. I think code only allows a one-eighth inch gap around the box.
    I&C Engineer (mostly WWTP) Lakee911's Avatar
    Aug 2005
    Columbus, OH
    Quote Originally Posted by frenchie View Post
    Good point.
    I thought it was 1/8" ... no?
    Dec 2006
    You're allowed 1/4" recess in noncombustible material - you're allowed 1/8 gap (bravo, Ian) around the hole.
    __________________
    DIY Member Ford2001's Avatar
    Sep 2009
    Manchester, Vermont
    Cool If the receptacles set back to far?
    You check with your local electrical supply house.
    See if they sell the Arlington, brand box extentions.
    I used, then, they have a lip that extends all the way around the
    outlet openning.
    Home Depot also see box extentions, and they come in different
    thicknes.
    I had have good luck with both products.
    I have also switch to using adjustable boxes, in places were the wall
    thickness in an unknown/unkown.
    DIY Junior Member Boo's Avatar
    May 2007
    California
    Be cautious about some of the plastic box extenders. The ones I bought at Home Depot recently have somewhat sharp edges and when you push into the existing box, they have a potential to cut the sheathing on the Romex. I had to file them smoother before inserting.
    DIY Junior Member Joe Werle's Avatar
    Nov 2009
    Indianapolis, IN
    Default plastic supply lines
    I've used 3/8" plastic supply lines, cut to the length needed to bring the receptacle flush with the surface of the wall. and drywall screws of various lengths seems to work in the plastic boxes. Both readily available.
    Quote Originally Posted by Joe Werle View Post
    You are treating the symptom and not fixing the probem! While doing this will move the outlet flush with the wall surface, the whole safety reason to do it in the first place is to protect the potentially vulnerable wall covering from possible sparks. Only moving the box or a box extender solve both the symptom and the problem.
    Jul 2007
    USA
    Thanks. I did go with the plastic box entenders (on my metal boxes and armored cable) and they seem to work an absolute treat.
    I like the way they add to the box size as well!
    Dec 2006
    Quote Originally Posted by Ian Gills View Post
    Oops - plastic extenders on metal boxes?
    Means now you need to pigtail a ground connection between the receptacle and the metal box.
    __________________
    DIY Senior Member SteveW's Avatar
    Feb 2005
    Omaha, NE
    Wouldn't the receptacle screws serve as the connection between the receptacle and the metal box?
