Originally Posted by
quote; (1st) I was thinking of asking my plumber to install TWO chase pipes because if we was to have hot water recirculating pump installed then the cold really needs to be separated from the hot supply pipe...right ?
WRONG! The cold and hot pipes should ALWAYS be separated. And a circulation system will NEGATE the effect of a mixing valve, NOT make it better. DO NOTuse a mixing valve and circulation system if you are going to operate the heater at more than 135-140 degrees.
