Originally Posted by
KBF
They didn't itemize the bid, but I suspect that the high cost is due to:
1) having to break a hole through the concrete foundation to connect inside, then make the connection and repour the concrete. It's in a really tight and awkward space, so may be more time consuming. And their labor rate comes to about $200/hr (based on their time and materials rates). This part alone will probably take about 1/2 of the time for the install, I'd guess.
2) using a trenchless boring machine (I expect I'm paying a premium for that versus using a ditch witch)
3) they spec Qline which looks like pretty expensive stuff - top end sort of product from what I can tell.
And I also expect it's the kind of company that charges in the upper end - I checked them out on angie's list before calling, and all the reports all pretty much said they do great work but aren't cheap.
But this is pure guessing on my part.
At this point I'm even thinking I'll do the trench, buy the pipe, lay it in the trench, but have those guys or some other plumbers come out to connect the 2 ends - I'm not too concerned about connected the meter end, but since connecting to the house is a lot more involved by busting up the foundation, I think it has the potential for things going wrong. So it might make sense to see if I can get a professional to do that one part.
