Results 1 to 6 of 6
Thread: Bathroom paint
    DIY Member Barry J's Avatar
    Mar 2007
    Mass
    Default Bathroom paint
    Looking for a good wall paint and ceiling paint for my bathroom that is mildew and mold proof. Last time I used the Zinser brand, put did white. This time I want white for the ceiling and a lighter blue or something for the walls.
    Barry
    Plumber jimbo's Avatar
    Any paint store has an additive packet that you can mix into a gallon of paint for mildew resistance. Look for a 100% acrylic gloss or semigloss at any good paint store.
    The best mildew preventive is ventilation. If you are sprucing up your bathroom, now might be a good time to address that. A small bathroom should have a minumum 100 cfm fan. The builders original might be half of that. For a modest $$investment, you can get plenty of CFM and also quieter. Look for maximum 1 sone.
    Default paint
    How about checking with the paint store for their recommendations, since each manufacturer might have a different suggestion.
    Jul 2007
    USA
    Or a window that opens.
    Jul 2009
    North Vancouver, BC
    Default Good Bathroom Paint.
    There are many great bathroom paints out there. The key with any bathroom painting job is to give the walls and ceiling a good clean and sanding. Once the walls and ceilings are cleaned up - give them 2 coats of Zissner "Cover Stain" Yellow label.
    I like Cloverdale Paint "Kitchen and Bath" line. Cloverdale is a Vancouver paint store but I'm sure your area has a good paint supplier and they will carry a kitchen and bath paint.
    Two top coats and no hot showers or baths for 2 extra nights and you will have a rock solid paint job. Most top end paints require 48 hours to fully cure.
    Good Luck
    I&C Engineer (mostly WWTP) Lakee911's Avatar
    Aug 2005
    Columbus, OH
    Quote Originally Posted by Ian Gills View Post
    Best option is both.
