Heat traps are not check valves. If the ball traps become noisy, just unfasten the pipe and remove them. In any case the heat traps are AFTER the point where you would/should install an expansion tank, so it would do NOTHING to eliminate thermal expansion if the heat traps were a problem, since it would ONLY occur in the hot side under those circumstances.
