Results 1 to 8 of 8
Thread: low water level in toto toilet bowl
    DIY Junior Member
    Oct 2009
    livingston
    Default low water level in toto toilet bowl
    The water level in the toto toilet bowl is very low. When I flush, the flapper closes before the tank is completely emptied. I replaced the flapper with the correct flapper. Any suggestions on how to keep the flapper open longer so the tank fully empties into bowl????
    The water level in a toilet bowl is determined by the weir not the amount of water poured into the bowl, and there is nothing you can do to change it. Some water spots are larger than others, but that is determined by design. The tank on low flow toilets is not supposed to empty. The flapper is designed to close when the prescribed volume of water has emptied. The "extra" water in the tank provides a little more pressure for the water that is emptying. You feel on a particular flush that additional water would be helpful, you can empty it just by holding the handle are couple of seconds. It would sound like you defeated the low flow with the flapper you installed.
    Make sure the rubber hose is pointed inside the overflow tube.
    This is what fills the bowl.
    The flapper drops quickly so the toilet will use 1.6 gallons or less.
    If the tank were to drain, it would be a 3.0 gallon toilet.
    DIY Junior Member
    Oct 2009
    livingston
    thanks so much, that was it. A picture is worth a thousand words!!!
    DIY Junior Member linksnut's Avatar
    May 2010
    San Jose, CA
    I have the same problem... and the rubber hose is pointed inside the tube... about 2 inches of the tank gets filled, not the usual amount. Is there anything I can do to adjust this?
    Very little water leaves the tank. The flapper will lift and drop.
    Are you wanting more water to leave the tank, or is there a concern about bowl water.
    If you slowly pour water into the bowl, you will find the top level it will take.
    First make sure that the fill tube is directed down the overflow tube.
    DIY Junior Member TimLind53's Avatar
    Jan 2014
    Washington
    Thank you so much. At some point my black hose got clipped on the wrong side of the white overflow tube (which results in very low water in the bowl). I've corrected this and used my label maker to put an instruction label on the inside back of the water tank just above the top arch of the black hose in the photo. That should jog my memory if I'm ever working in the toilet tank again.
  1. Toilet Bowl Water Level Alternates Level and Flush
    By leichte in forum Toilet Forum discussions
    Last Post: 09-06-2010, 10:21 AM
  2. Toto Promenade Sanagloss bowl water level
    By J Tony in forum Toilet Forum discussions
    Last Post: 12-23-2009, 10:36 PM
  3. Toto Aquia II bowl water level
    By ETsai in forum Toilet Forum discussions
    Last Post: 12-05-2009, 03:41 PM
  4. Adjusting Water Level in Toto Drake Bowl
    By steve56 in forum Toilet Forum discussions
    Last Post: 11-20-2005, 09:32 AM
  5. Toto Vespin water level in bowl
    By tonyr in forum Toilet Forum discussions
    Last Post: 05-03-2005, 12:59 PM
