Krow
That toilet is missing an adaptor and it uses a very sticky type of gasket (which seems as if it wasn't supplied to you.) the adapter is bolted to a regular flange and the openings will fit into this fitting. The entire porcelain is bolted/secured directly to the finished floor/tile floor from the back of the toilet using a ratchet type tool and lag bolts.
I installed one a few years ago, and as I understood it, it was made from an outfit in Quebec and then later sourced out to China (for the cheap labour)
I have to tell you that I would hate to be the guy servicing that toilet for a repair. No standard parts would fit in the toilet that I installed.
